500 2005 sportsman tail light disconnect switch
Old Jul 24, 2008 | 10:39 AM
KINGSCLEAR's Avatar
Default 500 2005 sportsman tail light disconnect switch
Has anyone hooked up a switch so you can shut your tail lights and brake lights off when you don't want to be seen? I'd like to hook it up so when I'm setting at night and I want to use my 12volt accessories or my work lights and I can turn the key on I won't have the tailight on . Or when I'm driving down the edge of the highway trying to get home at night I can be a little more stealth. I'm guessing just a switch wired into tail light wiring, but for it to shut tail lights and brake lights off it would probaly have to disconnect the ground
Old Jul 24, 2008 | 02:31 PM
hobbles's Avatar
Afternoon KINGSCLEAR
Yep, I did, I put the switch from Rad shack on my pod (top left), I cut and spliced into the brown wires from the rear lights. As for the break lights, if you use your foot pedal you won't have to worry bout them.
Old Jul 25, 2008 | 12:09 AM
trophytaker75's Avatar
Does this same fix apply for the 07 sportsman 500 EFI????????
Old Jul 25, 2008 | 08:46 AM
hobbles's Avatar
Mornin trophytaker75
I'm not sure, It should be the same wiring harness but I better let the boys that have more smarts then me answer that one. If theres any thing I can do to help, just let me know,
jayking232003
Dec 4, 2019 09:38 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
MrElussive
Dec 12, 2000 05:13 PM
MrElussive
Oct 19, 2000 09:50 PM
