'07 grizz 400
Old Jul 28, 2008 | 10:02 AM
mudfreak400's Avatar
Default '07 grizz 400
does anyone know how to disconnect the reverse speed limiter. i know the 450 has an override, can one be installed on the 400. i got off in a hole the other day and couldn't back out because of the limit. it really sucks.
Old Jul 28, 2008 | 12:00 PM
Krait's Avatar
The Kodi/Grizz 450 doesn't have an over-ride for reverse, only diff-lock...same as all Yamaha's I believe.
http://www.grizzhopper.com/Bearsden.html
I know this is only for the Grizz 660, but some ppl have done the same thing for the 400/450 and have said it works the same. Hope this helps.
Old Jul 28, 2008 | 12:23 PM
Thanks. I will look at my bike and see if this will work. Have you heard about anyone installing a clutch kit and/or jet kit?
Old Jul 28, 2008 | 12:33 PM
Krait's Avatar
Well there are jet kits and clutch kits available for the Grizz/Kodi 400, if thats what your asking. I personally don't know how much effect they will have on the bike, but jets kits are usually only needed to tune the quad...usually when you add an aftermarket airfilter & exhaust. Clutch kits generally help it to turn larger/heavier tires, helps in deep mud, etc...but usually takes away some top speed, and if the quad doesn't need the clutch kit, then you could end up over revving the quad when taking it to higher speeds.
Depends how you have your quad setup & how you like to ride.
Old Jul 28, 2008 | 08:19 PM
2FAST4URASS's Avatar
It's funny that you post this I have a 07 GRIZZ 400 too and a 99 PRAIRIE 300 which has reverse rev over ride and a few day's ago I went for a ride and let my brother ride my Prairie and I rode the Grizz and I pushed him out many times whille we was going through the mud holes foward ''but then we was messing around backing through some holes and the 2wd Prairie would go more places than the grizz in reverse I HATE PUNCHING THE GAS AND HEARING DURRR DURR DURR DURRR DURRR it has got me in alot of trouble a few time's not having enuff speed in reverse to clean the tire's!!! I love the atv but they should have had the override!!!! im gonna give the get-up Krait linked us to if you do it anytime soon let me know how it works out 4 ya...Jeremy
Old Jul 28, 2008 | 11:42 PM
Hebs's Avatar
well, the limiter is for safety. To easy to roll a quad in reverse with out a speed limiter... That being said, I wouldn't doubt you could override it the same as with the 450/660/700 grizzlies... You just need to ground out the reverse sensor that should connect to the top of the motor just like the bigger quads...
Old Jul 29, 2008 | 08:55 AM
I'm going to work on it this weekend. Will let you know what happens next week.
Old Jul 29, 2008 | 08:57 AM
I am having a hard time finding a clutch kit for the 400. Any suggestions?
Old Jul 29, 2008 | 10:42 AM
Hebs's Avatar
Dalton and EPI both make a clutch kit for the kodiak 400. Might want to do a lil more research, but I'm sure it's all the same...
Old Jul 29, 2008 | 12:32 PM
Guest
Guest
Posts: n/a
<div class="FTQUOTE"><begin quote>Originally posted by: Hebs
Dalton and EPI both make a clutch kit for the kodiak 400. Might want to do a lil more research, but I'm sure it's all the same...</end quote></div>
High Lifter makes a clutch kit for the kodiak 400 also, make sure to clutch for elevation and tire size, both are very important. Need any help give me a call.
RANDY KNADLE
OREGON TRAIL SPORTS
541-523-3500
