Polaris Trail Blazer 250 Gear Box Casing Removal?
Old Jul 29, 2008 | 02:50 PM
dykzeulb's Avatar
Default Polaris Trail Blazer 250 Gear Box Casing Removal?
my chain broke and whipped around and cracked the hell out of my 2002 TB 250's gear box casing..Does anyone have a writeup on replacement or know where to find used ones, what other quads have the same ones? I found one for a 2001, but it doesnt look a whole lot like mine..
Old Jul 29, 2008 | 02:54 PM
dykzeulb's Avatar
Also needing plastics and some other MISC parts for this, if anyone knows of any, let me know!!
Old Jul 29, 2008 | 03:00 PM
blaster24's Avatar
parts.polarisind.com this site will tell you what parts will interchange hope this helps you!
Old Jul 29, 2008 | 03:03 PM
blaster24's Avatar
looks like the 2001 trail blazer will work the cases have the same part#
Old Jul 29, 2008 | 03:08 PM
dykzeulb's Avatar
Cool cool I appreciate it, does anyone know how to get this thing off? Does just that one side come out or do I wanna take out the whole gear box when I do it? It's the little box, where the little top sprocket comes out of.. It looks like it is split in two, however the bolt removel is being a royal PITA
Old Jul 30, 2008 | 11:41 AM
blaster24's Avatar
now that i dont know! if you look at the polaris site i gave you it shows a part diagram dont know if that would help you in removal.
Old Jul 30, 2008 | 02:12 PM
blaster24's Avatar
i just found an older post it says you have to pull the whole tranny out.it also said that any 2000 up trailblazer or trailboss 325 or 330 trailboss would work. go into the search box and type in 2001 trailblazer and you should find plenty of post on the trailblazer. hope this helps you!
Old Aug 1, 2008 | 04:05 AM
dykzeulb's Avatar
Alright, I started pulling off plastic, removed the driven clutch, however how the hell does the drive clutch come off? Also, would I be safe having that gear casing welded?
Old Aug 1, 2008 | 12:03 PM
blaster24's Avatar
That im not sure how to do. Go to the search box and type in trail blazer clutch removal and see what you can come up with. You will probably have to remove the gearcase and take to a welder to determine if it can be welded. If the search doesnt help you start a new thread im sure someone on here can tell you how to remove it. Hope this helps you!
Old Aug 1, 2008 | 12:04 PM
blaster24's Avatar
Try here tahelp on ebay he has some used polaris parts.
jace
Sep 10, 2020 08:30 PM
hoopduerr
Jun 10, 2015 03:00 PM
PolarisPower500
May 17, 2015 02:28 PM
covert
Apr 29, 2000 09:54 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
