scrambler output shaft bearing thing
Old Jul 29, 2008 | 05:12 PM
kukerdan's Avatar
Default scrambler output shaft bearing thing
hey, I have a 96 Im rebuilding,
Where the shaft comes thru the frame, for the FWD and disc brake,
http://www.bikebandit.com/hous...ematic/m5472sch496020
I believe #27 on this scematic..
the 'bearings' inside are shot, fell out.. are these just the brake seals,
listed as # 24 ?
Or do I need to replace the entire piece?
Thanks
Old Jul 29, 2008 | 06:53 PM
user493's Avatar
Moto Psycho
I dunno, but you can see the part names and numbers here: http://parts.polarisind.com/Browse/Browse.asp
Old Jul 29, 2008 | 09:41 PM
This is a shaft support bearing plate and grease zerk assy,will come with bearings installed. If locking collar not supplied(behind bearing with set screw) can reuse old one. I'm replacing inner sprocket on an old 93 350 and has same set up.
Old Jul 31, 2008 | 10:03 AM
kukerdan's Avatar
Ok, just making sure.. thats part # 27 on the diagram right?
It just looks like a flat plate in the picture,
it is This part right: http://cgi.ebay.com/ebaymotors...116QQitemZ330185816404
Old Jul 31, 2008 | 12:44 PM
kukerdan's Avatar
ok, im about to buy it, i hope thats the part
Old Jul 31, 2008 | 02:42 PM
kukerdan's Avatar
*crosses fingers*
Old Jul 31, 2008 | 10:02 PM
Yep,right part and I believe the locking collar comes with a new kit or re use old one. Make sure grease fitting on bearing housing fits inside and at top.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
toonces
Oct 16, 2019 12:11 PM
D-Hagz
Jul 4, 2015 02:19 AM
Mphillips
Jul 2, 2015 07:20 PM
