sunl 90 no spark
im looking for a little help with a sunl 90 w/ no spark. ive checked it back to the cdi and that has no power going to it. anyone have any idea of which wire on the cdi is supposed to be power into the cdi box and where it comes from ? i also removed the middle wire on bottom row of cdi box plug to cut out all the safeties too.unfortunately evrytime i move something more wires fall apart.ive got alot of cheap connectors that have to be cut out and repaired.also does anyone know how to eliminate the alarm system ? id like to get rid of all that junk.
thanks.
i did try to call raceway but the techs were always busy so maybe if one reads this they can help? i did buy it there a couple yrs ago
thanks.
WOW, I guess this isnt a problem anybody else has had? What I really need to know is what wires coming out of the stator have power when turning the engine over ? I beleive the stator is no good but I dont want to just guess. What`s more amazing to me is Raceways lack of help,I`ve called at least 7-8 times this week and tech service is just too busy with parts. I even left my ph. # and waited for a return call,what a joke.
I hope your reading raceway. I will be buying my parts elsewhere,as well as my kids grow I wont be buying anymore quads from you and there only 7&9 so I hope you sell alot of parts.Customer service is important and it looks like you just dont care about the customer..Thats my rant,so if anybody can help again it would be greatly apreciated.
Thanks in advance
Thanks in advance
Try this as a starting point. It is a wiring diagram for an 'older Honda' with a CDI Ignition. Most of the wiring 'color codes' should be similar - if the Chinese did their 'copying job' correctly.
Honda C70 wiring Diagram
Then Go: Smoking Diagrams with Left Navigation Frame
C50 70 Cub Passport
c70 elec82 (27.6 kb) the second listing
C50 70 Cub Passport
UPDATED INFO.
I went thru the whole thing again today,safety switches,wires etc. still no spark. I checked all the wires coming from the stator with a test light and which was connected to grd. on the battery. Turning the engine over with the starter to test the statorThere were 5 wires and this is what i got for any 12 v readings.
blue/wht.=nothing
green. =nothing
blk./red =nothing
white = it lit the test light very dim
yellow =same as white wire,very dim bulb
I`m thinking its a bad stator because it didnt really light up and I couldnt get any voltage readings at all when using a multimeter set at 12v dc none of the wires gave more than 0.01 volts. If anyone can help out me and my son we would greatly apreciate it.
thanks in advance
blue/wht.=nothing
green. =nothing
blk./red =nothing
thanks in advance
NEW UPDATE:
I know its been awhile but I just today got to finally work on it again today due to a family medical emergency.
Anyway I took it apart and it looks like new, no dirt oil etc.
Im ordering a new stator i found on ebay.at this point i dont know wha else to check
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
