20 Amp Self-resetting breaker
Old Jul 31, 2008 | 06:45 PM
caddis_drift's Avatar
Default 20 Amp Self-resetting breaker
I have a 1996 sportsman 400. It has been sitting in my dad's garage for 6 years and I am trying to revive it on my own. Of course I have no known mechanical skills so I am learning as I go.
I removed, disassembled, reassemble, and re-installed the carb. Changed and charged the battery, and now it starts with the starter and/or one pull on the pull start. It runs great except the low beams, dashboard indicators, fan, AWD indicator, etc. are not working.
The High beam light works and one indicator light is working.
What are my chances that the 20 amp self-resetting breaker has failed and how can I test it? It is in the sealed pouch and I am not really excited about cutting it open if I don't need to.
I think my next step after the breaker is to look at the Stater???
THanks for any help and suggestions.
Rick 20
Old Jul 31, 2008 | 09:44 PM
Dont have to cut open,just use test light and check each side of wire into pouch BUT have seen perfectly sealed pouches before and have corroded thermal fuse body and terminals inside! If in doubt about fuse just slice,not that expensive.
Old Aug 1, 2008 | 12:10 AM
BlueRubie's Avatar
just had that happen on my machine a moth ago went to walmart spent $3 on a new breaker and bam lights camera action (oh yea dont get at dealer they want $30 FOR IT )
Old Aug 1, 2008 | 03:40 PM
Thanks I will be working on it this afternoon with a cold one in my hand. Of course only after going to Wally World
Old Aug 1, 2008 | 03:41 PM
Thanks... I will get out my test light.
What do you think the liklyhood that the fuse is bad?
Old Aug 1, 2008 | 10:54 PM
50/50 chance,with electrical ANYTHING possible! Test light my favorite tool,check if power going to light harness, and other problem connections,some could be just bad connections or bulbs. good luck
Sw00p
Sep 24, 2015 02:50 PM
Alex G.
Sep 19, 2015 06:34 PM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 5, 2015 05:55 PM
02SP700
Apr 8, 2003 08:56 PM
