Polaris 330 2003
Old Jul 31, 2008 | 09:39 PM
bowkiller's Avatar
Default Polaris 330 2003
I just purchased a 2003 Polaris 330 2x4. I have no spark, the spark plug wire was broken and I order the wire and coil. and I am hoping that fixes the problem. If that doesn't work does anyone have any suggestions on what to look for to fix this problem. your help will be appreciated.
Old Jul 31, 2008 | 09:53 PM
Go to auto parts store and get a length of 7mm wire, twist into coil,check grounds and see if have spark (If havent pulled out old wire,just pull down rubber sleeve from coil base and pull out old wire,they just put a little sealant to help keep in place) hold wire to any good ground.
Old Jul 31, 2008 | 10:11 PM
bowkiller's Avatar
thanks for reply.. first of all I engaged the hand break and made sure it was in park. I peeled back the wire and checked it on a good ground and still no spark.
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
95wolv
Jul 17, 2015 08:13 PM
