95 POLARIS SPORT 400L
Old Aug 1, 2008 | 10:40 AM
POLARIS/SPORT400L's Avatar
Default 95 POLARIS SPORT 400L
I HAVE HAD THIS 95 POLARIS SPORT 400L SINCE IT WAS NEW, I AM HAVING A PROBLEM WITH IT FALLING ON ITS FACE. I CAN GIVE IT FULL THROTTLE AND IT WILL GO AROUND 40 YARDS FINE AND FALL ON IT NOSE. ANY IDEAS WHAT COULD CAUSE THIS
IT HAS SAT FOR 8 YEARS AND I JUST GOT IT OUT THIS SPRING FINALLY..........I HAVE REPLACED THE FOLLOWING:
BATTERY
SPARK PLUG
FUEL LINE
REBUILT THE CARB
I CHECKED THE REED VALVES THEY LOOKED FINE AND I CLEANED THEM
IT WAS FALLING ON IT'S NOSE BEFORE I REBUILT THE CARB ALSO!!!!
MAYBE YOU GUYS CAN GIVE ME SOME IDEAS ON WHAT TO CHECK???????
Old Aug 1, 2008 | 02:09 PM
sjbr549's Avatar
have you checked the vent lines?
any air leaks from the boots?
the air neddle might be set wrong. mine is 2 1/2 turns out from bottom
does it rev up in nuetral fine?
could be a clutch issue. rust on the buttons or something of that nature
Old Aug 1, 2008 | 02:19 PM
im not sure about the vent lines.............which one goes where
book i have doesnt give to much detail
there are 2 lines that come off of the carb where do they go...........i replaced the old carb boot and stuff?????????????????????????
i have one hooked into crank and the other somewhere else????????????
Old Aug 1, 2008 | 07:49 PM
ftwflh's Avatar
take the gas cap off and try it.This will vent the tank
Old Aug 1, 2008 | 10:25 PM
crashnrole's Avatar
plugged exhaust??
Cole Hadden
Jun 15, 2025 09:05 AM
RickyMac
Mar 5, 2016 07:27 AM
1988josh
Ask the Editor
Jul 16, 2015 09:43 PM
John Boy
Jul 13, 2015 11:16 AM
black_thunder
Jul 9, 2015 05:58 PM
