1995 2 stroke polaris 400 4x4
Old Aug 3, 2008 | 09:34 AM
mikieday's Avatar
Default 1995 2 stroke polaris 400 4x4
i have to admit i have never changed it...i dont have the book (purchased bike used) i pulled the dip stick tube and i have gas in the gear fluid, the vent tube runs from the carbs to the trans??????????
so will 80/90 weight be ok , or should i use something else
thanks
Mikie
Old Aug 3, 2008 | 03:59 PM
Vent line on trans should be separate from carb drain and vent lines. Models before 96 used a graphite trans flluid,but NOW all machines use AGL even the older ones. 80/90 too thick, if not Polaris brand use oil suitable oil for chain case transmisions. Can usually find at auto stores.
Old Aug 3, 2008 | 09:41 PM
mikieday's Avatar
any idea how many ounces it holds
i have 12 oz chain case oil bottle for my arctic cat snowmobile
Old Aug 3, 2008 | 09:46 PM
Holds between 16-20 ounces. Install 16 oz,then check dipstick,add as required to full mark.
Old Aug 3, 2008 | 09:54 PM
mikieday's Avatar
great...i appreciate it...i will have to get another bottle...i have 5w-50 synthetic , would that be good enough or is it too heavy
thanks for the great info, and the help...
Mikie
Old Aug 3, 2008 | 11:05 PM
As long as it says for chain case type transmissions!
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Gnuters
Jul 19, 2015 10:03 AM
Shifts
Jul 3, 2015 07:59 AM
