Problem Starting yfz 450
Old Aug 3, 2008 | 06:53 PM
Gnut32's Avatar
Default Problem Starting yfz 450
05 yamaha yfz450
It turns over but it does not start. Plug is getting spark, getting gas. I do have a kill switch hooked up, and everything is hooked up right. card is clean and jetted 2 specs....Any ideas??????
G
Old Aug 3, 2008 | 08:45 PM
pistal pete's Avatar
hows the compression is it tight when u kick it? if its electric startuse a compression tester. also ive had friends whove had probs on there yfzs w/flywheel key shiering in half skrewing the timing.
Old Aug 3, 2008 | 09:50 PM
Gnut32's Avatar
I have a yfz450 Quad it has a electric start not a kick.....
Old Aug 3, 2008 | 10:11 PM
ok, many of them do hav kick starters, i dont no y, but they do. did u check those possible problems yet?
Old Aug 11, 2008 | 10:16 PM
ablokzyl's Avatar
One quick thing to try is to just drain the carb bowl. After any YFZ450 sits in our shop for more than two weeks they dont start well unless you drain the bowl. Hope this helps.
Old Aug 11, 2008 | 10:18 PM
ablokzyl's Avatar
Oh and YFZs dont come with kick starters from the factory. They are an add on for people who want to remove the battery and starter.
Old Aug 11, 2008 | 10:45 PM
o, ok my bad
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
