polaris clutch clunk on decelleration
I bought a used 07 700 sportsman no ebs or adc, when I go down a grade or slow up it goes kachunk kachunk kachunk, my dealer said that a lot of 700's do this,my friends 500 doesnot do this, any thoughts or ideas on this.By the way it had only 300 mi on it when I bought now has 600, has done it since I got it , no other problems, great machine,I put a new belt on and inspected the clutch,the belt was still good
700 and 800 engines have more noticeable drive line lash than 500 engines because more torque. A little annoying at times but normal. Straight out of crate will do this. Just maintain and will be a good machine. Good luck
Yep - right on, the Polaris twins use a TEAM secondary clutch which is the source of that clunking. TEAM redesigned the clutch to include rubber dampeners which help alot. You can buy the upgraded clutch with dampeners for about $200 if it bothers you, but other than the noise (which you tune out pretty quickly) theres' no harm to it.
Shifts
14
Jul 13, 2015 08:41 AM
