About to do a top-end rebuild...any advice?
Old Aug 6, 2008 | 12:12 PM
rjcruiser's Avatar
Default About to do a top-end rebuild...any advice?
I recently purchased a couple of 110s and am going to be getting them running.
One of them runs, but smokes really badly. So....I bought a top-end kit off of ebay and it will hopefully get here around the same time as the clymer manual I bought off of amazon.
So, I'll have instructions, but was wondering if there was any advice or tips that any of you could give me before I dig into the project. Thanks,
RJ
Old Aug 6, 2008 | 05:41 PM
3wheelersforlife's Avatar
Do you have all the tools to do a top end?
Old Aug 7, 2008 | 12:07 AM
rjcruiser's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 3wheelersforlife
Do you have all the tools to do a top end?</end quote></div>
I do have a torque wrench.
Anything else that I'll need? I'm hoping to have everything by this weekend to do it, but it might have to be next week/weekend.
Old Aug 7, 2008 | 07:30 AM
What does the topend kit have for parts?
Old Aug 7, 2008 | 10:18 AM
rjcruiser's Avatar
remanufactured cylinder, piston and ring kit, top end gasket kit,
Bought off of ebay from GH Discount ATV.
See kit/ebay item here.
http://cgi.ebay.com/ebaymotors...4524&_trksid=p3907.m29
Old Aug 7, 2008 | 07:05 PM
You mite need new valve guides and valve guide o rings seals.That is if the oil is getting past the o rings.
Old Aug 8, 2008 | 09:37 AM
rjcruiser's Avatar
I suspect it probably is...but how would I know for sure? I guess when I open it up, I'll be able to see the rubber on the O-rings...but what about the valve guides? The reason I say it probably is is because the thing burns oil like a smoker and wants to cut out after about 30 seconds or so. Then it will start right back up again and go for about 30 seconds. Also, I've got the air intake stuffed so that it will produce enough vacuum to suck the fuel into the combustion chamber. I will say, the spark plug looks normal and doesn't come out looking black.
Also, per the valve guides on dratv, you have to have a valve guide reamer. What is that and is it necessary?
Do you think the local auto parts store will have a generic O-ring that will work, or do I need to order specific from an ATV place.
Appreciate the help 3wheelersforlife.
Old Aug 8, 2008 | 07:04 PM
It you need to do the valves and guides you will be better off buying a Vesra complete gasket kit.This will have all the parts you will need at a small cost.The valve guides can be hard to get out,They are pressed in.You can get them out if you are injunuitive...spelling.You can also take the spring keepers out of valve spring if you up to it.You will need a magnet for this and a 10mm open end wrench.Make shure you drink an AMP energy drink.lol
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
