450r
Old Aug 6, 2008 | 09:36 PM
kfxrenegade08's Avatar
Default 450r
have an 05 trx 450r kick start no battery..lights and fan will not work, but do if i jump them to a battery, it runs fine but no lights and suggestions
Old Aug 6, 2008 | 10:24 PM
twentycharacters's Avatar
Default 450r
uh, the fan isnt supposed to be on all the time on the 450R - it's thermostat contralled - only when reaches hot temp and not enough airflow thru the radiator is how it is designed to work.
the lights, maybe bulb? switch, wiring somwhere if it NEVER comes on??
Old Aug 6, 2008 | 10:30 PM
Default 450r
yes i know but the guy i bought it from said that its never come on, honda shop says the two are wired together somehow
Old Aug 6, 2008 | 10:47 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 450r
kfxrenegade, PM me you email addess and I will send you a scanned copy of the wiring diagram for an '04 - '05 450R
Old Aug 6, 2008 | 11:52 PM
Pirate Biker
Limping Rider!
Default 450r
According to the wiring diagram there is a black wire coming from the light switch that is tied into the cooling fan motor, the carburetor heater, the rear brake light switch, the temp indicator light and the front brake light switch.
Old Aug 7, 2008 | 12:00 AM
Pirate Biker
Limping Rider!
Default 450r
Your fan motor is controled by the CDI which gets it's signal from the engine coolant temperature sensor.
Does your brake light come on at all? When you put the foot brake on or the hand brake?
All of these components get their power from the same lead.
Old Aug 7, 2008 | 06:53 AM
HondaMechanic's Avatar
Default 450r
I gave all these tests over a week ago did you do any of them..?..
Here are the tests for the fan , headlights .. Also tests for the alternator & regulator/rectifier ..
FAN
LIGHTS
ALTERNATOR & REGULATOR/RECTIFIER
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Asaran
Oct 8, 2015 11:14 AM
Aug 5, 2015 02:10 AM
dorene
Jun 5, 2015 05:25 PM
