carb Help for a 16yr old
Old Aug 7, 2008 | 12:55 AM
ray.sandefur's Avatar
Default carb Help for a 16yr old
im 16 and dont quite understand how a carb works besides mixing air and fuel. what all do the jets do and how do they work? and the needle? im not sure i would like it if some one could give me carb 101 in a nutshell ...... im thinking about putting a k/N on my old warrior and im wondering if i need to rejet it or anything ??? i just dont wanna screw something up
any help is appriciated
thank you
Ray
Old Aug 7, 2008 | 01:18 AM
91Warrior357's Avatar
you usually wont need to rejet unless you use an aftermarket exhaust or you run your bike with no lid on the airbox...ok this really depends on the kind of carb, but the opening of your carb, the hole is called the venturi below it is a bowl and theres a float which has a needle valve below it,when the fuel level reaches a certain level in the fuel bowl it pushes that float up and shuts off the fuel from entering into the bowl until it needs more, that way the jets are able to draw fuel, typically the throttle valve controls 0%-35% of the throttle opening, the needle jet and jet needle control about 15%-80% of throttle opening and the main jet controls 60%-100% and usually works in that order, the jets basically cause the fuel to vaporize as it goes into the venturi. any more questions ill try to answer...
Old Aug 7, 2008 | 01:20 AM
Doctorturbo's Avatar
GOT BOOST!
Ray, your doing a very good thing by asking questions first.
Here is a good answer for you:
Carb 101
Read this and if you have more quetions, just ask. There is a great bunch of people here willing to help you.
Old Aug 11, 2008 | 06:03 PM
blaster24's Avatar
ray i have a warrior manual on cd if you need anything from it let me know and ill see what i can do for ya!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
