450 foreman
Old Aug 8, 2008 | 11:43 AM
contentsunderpressur's Avatar
Default 450 foreman
How do I get the timing chain off? Do I have to take the clutch and the centrifical clutch deal off the crankshaft? It looks like the chain won't get by the clutch and the centrifical clutch on the crankshaft looks too big for the chain to get over. I decided just to pull the engine out so I can see all that stuff without anything being in the way but can't get the driveshaft that goes from the motor to the front chunk out. How do I remove that?
Old Aug 8, 2008 | 03:39 PM
HondaMechanic's Avatar
Default 450 foreman
Yes the centrifugal & manual clutches have to be removed to change the cam chain .. You remove the mounting bolts from the front differential (and the front differential mount) slide the differntial forward all the way then to remove the drive shaft just slide the coupler forward off the output shaft of the engine .. A large screwdriver or prybar is handy for this ..
Old Aug 9, 2008 | 11:53 AM
Default 450 foreman
Ok. Do I have to use some sort of puller to get the clutchs off?
Old Aug 10, 2008 | 01:03 PM
Default 450 foreman
Bump
Old Aug 10, 2008 | 01:19 PM
Gimpster's Avatar
Default 450 foreman
Yes, If you cannot borrow a puller from your local Honda dealer, go to ebay. A store there called Pit Posse has a unique puller set that should get the job done. It is a universal puller set with quite a number of pieces in it. normally sells for around $70 plus freight. The clutch puller from Honda will set you back this much alone.
----- Gimpster -----
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
