Can a quad be stored on it's rear bumber without gas leaking out of the carb or tank?
Old Jan 27, 2001 | 11:58 PM
jefffoxsr's Avatar
Any other drawbacks?
I have a friend who can't get one unless he can store it as such. Thanks.
Old Jan 28, 2001 | 12:04 AM
MNT's Avatar
MNT
Gas can't leak if there isn't any to leak, drain it before storing.
Old Jan 28, 2001 | 04:17 AM
Diogenes's Avatar
If the tank is not so full the fuel will spill from the breather hose in the gas tank cap when elevated,
1. CLOSE the gas tank petcock, turning it to the "OFF" position.
2. DRAIN the carburetor by dumping the gasoline from the float bowl with the drain screw, or by running the engine 'til the carb is dry.
If the petcock seals, no fuel should spill, beyond perhaps a nominal amount of residue in the fuel lines.
MNT's approach, drain the tank, is the safest and most thorough approach, especially if the storage area is near any source of spark, heat, or flame, like a hot-water heater, furnace, electric motor, etc.
Diogenes
Old Jan 28, 2001 | 10:05 AM
love250x's Avatar
I agree w/ those guys,empty the tank and the carb.
Old Jan 28, 2001 | 07:50 PM
joelpolaris's Avatar
If the quad is a four stroke with a dry sump oil system, you could have a problem. The oil resevoir has a vent tube on most quads and when the quad is stood up on end, the oil could drain through this tube which is usually connected to the airbox, thereby filling the airbox with oil. The best thing to do is ask the dealer.
Old Jan 29, 2001 | 02:59 AM
cartman308's Avatar
ask my dealer?!?!?! aaaahhhahaaaaaahhaAAAGHHHAHHHAHAHAHAaHG
AHHHHHHEHHEEEEEEEHEHEHHEHHEHAAHHHHHHHAHA
HEHHHEH......i'm sorry. maybe your dealer is better than mine.
Old Jan 29, 2001 | 10:34 AM
86atc250r's Avatar
The vent tube for the oil rez on the 400EX connects to the cylinder head, any overflow would flow into the engine instead of on the floor.
Old Jan 29, 2001 | 12:19 PM
retro's Avatar
I have a small inline valve in my cap breather hose that allows air in the tank but not out. They cost about $3.
ERIC
Old Jan 29, 2001 | 05:03 PM
BrianWSNC's Avatar
OUCH.. don't forget your BATTERY!.. you don't want that to leak all over your quad and eat it away!
Old Jan 29, 2001 | 09:04 PM
Monica81's Avatar
the batt is a sealed no worrie's there
