Output shaft / sprokects / brakes order and assembly please help so i can ride tomarrow!
Old Aug 8, 2008 | 10:04 PM
kukerdan's Avatar
Default Output shaft / sprokects / brakes order and assembly please help so i can ride tomarrow!
Hey everyone
I finally got my last two parts, the clutch cover and the output shaft support bearing.
On the bearing , Could anyone tell me what order things go in, including seals and clips, from the trans foward.
I have sprocket, clip brake seal, support bearing, brake seal, brake, clip ring,
front drive sprocket /bolt/washer/big washer
the brake seems to have some play, is this normal?
Is the caliper solid on the rear and the disc is what has the play?
Also, the studs that hold the support bearing in, do the nuts go on the outside of the
bike or the inside..
also what side of the disc faces out? if i turn it one way it barly touches the studs.
I followed the schematic but i cant really tell what
way things go, and it is just a little confusing,
could anyone show a real picture or explain it to me better?
Thank you so much
Old Aug 9, 2008 | 08:19 AM
kukerdan's Avatar
anyone?
Old Aug 9, 2008 | 09:19 AM
kukerdan's Avatar
ok, I found some posts that say the disc brake is suppose to float
So, part 24, the brake seals, do they go inside the output shaft support bearing, or do they float on the shaft?
My new support bearing came with seals installed
scaldwellk
Jun 19, 2015 05:08 PM
Big600twin
Jun 10, 2015 03:01 PM
wildbill59
Jun 9, 2015 02:28 AM
clsharky
Jun 8, 2015 11:38 AM
volsgo30
Jun 4, 2015 06:07 PM
