taotao 250D battery charge??
Old Aug 10, 2008 | 04:54 AM
theatv's Avatar
Default taotao 250D battery charge??
Hello and geetings to all [img]i/expressions/face-icon-small-happy.gif[/img]
We have a taotao 250D which we brought home, we put the acid in the battery
and tried to start the engine and it sounded like it wanted to but it
didn´t start. We took out the battery and took out the stoppers from the
battery for about two or more hours then we put them back again, but now
the engine doesn´t even sound, looks like it has no charge however using
a multimeter it says about 12.3V, if you have experienced this how did you solved it? or do you think it needs to be charged?
I think it needs to be charged (how?) because the first time we put the battery the lights were turned on and they did very well unfortunately not the engine [img]i/expressions/face-icon-small-sad.gif[/img]
Hope you guys can help us
Old Aug 10, 2008 | 03:08 PM
ghcoe's Avatar
I would charge it. If you have a Harbor freight near by they sell inexpensive chargers. Also check all you connections and make sure they are good. A bad connection can make all the difference. You can watch the voltage on your multi-meter under cranking to see what the voltage drops to. If it drops below 10.5 it will need to be charged.
Old Aug 10, 2008 | 06:45 PM
Mitchal's Avatar
Try jumping it with jumper cable to your car?
New spark plug, is the choke on or off?, fuel valve open or closed
Old Aug 11, 2008 | 12:46 AM
theatv's Avatar
hey guys! well my little chinese girl has its battery charged once again, now the problem is different I'll post it in another thread [img]i/expressions/face-icon-small-happy.gif[/img] thanx
Old Aug 11, 2008 | 09:25 AM
Coloradotrailrider's Avatar
Those new batteries need to sit for about an hour after adding the acid to them. After that they need to be put on a trickle charger for about 4 - 5 hours. A fully charged batteries voltage is 12.6 volts. Don't rely on the ATVs charging system to charge a new battery.
Polarisman1123
Sep 13, 2015 10:06 AM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Unzzy66
Jul 11, 2015 10:01 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
