front engine sprokket for warrior
Old Aug 10, 2008 | 11:53 PM
ray.sandefur's Avatar
Default front engine sprokket for warrior
i have a warrior and it seam like the front sprokket thing that attaches the chain to the engine is to small.. the warrior has a lot of tourque it seems like so i was thinking about putting a 14 tooth or mabye a 15tooth sprokket on. i think that it has a 13tooth (stock) just when i ride it seems like it could go a lot faster.
just wondering if any one had any info
Ray
Old Aug 11, 2008 | 12:20 AM
91Warrior357's Avatar
yea a stock warrior goes around 55 stock and a 13 is the stock size, im guessing you have 20 inch tires too which will slow ya down a lil, but i wouldnt go bigger than a 15 tooth. a 14 will give a little more top end but just remember that it wont be able to accelerate as fast.
Old Aug 11, 2008 | 12:42 AM
so should i go 14 or 15?
Old Aug 11, 2008 | 12:08 PM
NA&CH's Avatar
I was thinking about doing this also. Would you change the rear out also?
Chris
Old Aug 11, 2008 | 01:02 PM
Raptor450's Avatar
I would keep the stock rear (40 I think) and change the front to a 14 tooth. 15 is too big unless you have a built engine. The 14 tooth will take away from the bottom-end torque, but will add 2-3 MPH to your top speed, plus you can use 1st gear more in tight trails and you can wind the gears out longer before shifting. The 14 tooth works much better if you have a slip-on pipe, filter, jetting and 20" rear tires.
Old Aug 11, 2008 | 03:24 PM
does it matter what kind of sprocket i get or does it have to be a certian kind to fit a warrior ??? i was ganna buy one of ebay for like 15$ but will it work with my warrior? and how hard is it to switch a front sprocket??
any help is appreciated
Ray
Old Aug 11, 2008 | 06:17 PM
as long as it says it should fit then it should work, renthal,JT,RK are nice, id stay away from moose and parts unlimited and theres a few other brands on ebay that im not sure of how good they are, as far as removing it its easy just leave it in gear and take the nut off and it will come right off
MikeyBoyesq
Nov 27, 2020 02:44 PM
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
scaldwellk
Jun 19, 2015 05:08 PM
mikey426
Jun 17, 2015 03:53 PM
