2003 kodiak 400 4wd engage issue
Old Aug 11, 2008 | 01:58 PM
stingray666's Avatar
Default 2003 kodiak 400 4wd engage issue
So I am at a complete stop and I hit the button to engage 4wd. i hear the motor engaging but the indicator lamp doesn't go on. Is it possible that the lamp is bad and that it is engaging OK? Just don't want to get caught thinking that 4wd can get me out of a situation and find out that I can't get in 4x4 mode.
Old Aug 11, 2008 | 02:20 PM
PolarisSMN400's Avatar
try jacking up both ends and then put it in 4wd, if only 2 wheels spin than it isn't engaging.
If you dont have a jack try putting 2 logs about 1ft apart and riding onto them. Make sure that you have someone who can pull you off when your done testing. Also make sure both logs are thick enough to lift both sets of wheels off the ground. also make sure you have a full skid plate to reduce the risk of denting necessary parts.
Hope I was of help, ill check back later.
Old Aug 11, 2008 | 06:33 PM
holters's Avatar
put it on concrete and try to turn in a circle. i can always tell if im in 4wd on concrete.
RedRancher
Oct 15, 2020 01:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
RedRancher
Jul 10, 2015 06:36 PM
