2000 trailboss 325
Old Aug 11, 2008 | 05:27 PM
blaster24's Avatar
Default 2000 trailboss 325
what is the biggest size tire i can put on this bike using the stock rims? looking for a little more ground clearance.
Old Aug 11, 2008 | 09:04 PM
user493's Avatar
Moto Psycho
I don't know what will fit, but if you put anything on more than 1" over stock you might have to get a clutch kit. You only gain 1/2" of ground clearance for every 1" inch taller the tires are. So if you wanted 2" more ground clearance you would need 4" taller tires.
Old Aug 13, 2008 | 03:44 PM
blaster24's Avatar
I do alot of trail riding and also a lot of hunting with the boss it still has the original 489s on it are these good tires or shuold i get something else they seem to get good traction though and man can that thing climb a hill!
Old Aug 13, 2008 | 03:51 PM
scootergptx's Avatar
Supersock
Hired Gun!
For the boss, the 489 is a good tire.
Like Jumbofrank said, you may want to get a clutch kit too.
Old Aug 13, 2008 | 04:23 PM
blaster24's Avatar
What kit would you recomend? Scooter if i recall you own a 325 boss what all mods did you do too it like ive said i mostly trail ride and do some woods riding while deer hunting etc. can i put a winch on this bike? thanks alot scoot!
Old Aug 13, 2008 | 04:34 PM
Supersock
Hired Gun!
Still have the stock size 489's on mine. I have piped it, added an K&N filter, re jetted and changed the primary spring on it.
Mostly trails and some mud. Surprising what it can go through for just being a 2wd.
Don't like where the mount for the winch is on most kits. Sits in front of the bumper. I had a steel plate welded to the top part of my bumper, just in front of the nose plastic. Never did put the winch on as I bought another quad, and this is a loaner now.
Advantage of the higher mount is a big plus if you get the front stuck. And you're not using the winch as a brush guard.
Old Aug 13, 2008 | 04:36 PM
Supersock
Hired Gun!
I got the stage 1 kit from Rick Ritter. Included the pipe, jets, high flow air filter and vents for the air box. Would use caution on the vents for the air box if you do a lot of swimming with the quad.
Good price and excellent customer service.
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
