2007 Grizz
Old Aug 13, 2008 | 01:06 AM
bigbenII's Avatar
Default 2007 Grizz
Have 4000 miles on it and it quit charging the battery. Fuses are OK. You would have thought Yamaha would have a way of telling you weather the system is working instead of waiting till the Battery is dead.
Old Aug 14, 2008 | 05:39 PM
taggart's Avatar
Default 2007 Grizz
if you put a volt meter on your battery it should read around 13.68 volts . if the voltage goes down when you rev it up its the rectifier thats gone , if your rectifier is ok its probably your stator needs rewinding . check your rectifier first . it would be good if they had a charging light on the dashboard .
Old Aug 15, 2008 | 12:32 AM
bigbenII's Avatar
Default 2007 Grizz
Thanks for the reply. The votage remains the same ,12.5, weather running or not.
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
toonces
Sep 5, 2015 01:14 PM
