200S vs 200M question
Old Aug 13, 2008 | 07:51 AM
bdlight4's Avatar
Default 200S vs 200M question
I currently have a 1984 200m and am looking at a 1984 200s. I do not see a difference except for electric. Could anyone please tell me the difference? Also, where can I purchase new fenders? Thanks for the help.
Old Aug 13, 2008 | 07:52 AM
3wheelersforlife's Avatar
The forks are different.The S has better ones.
Old Aug 13, 2008 | 06:18 PM
scary132's Avatar
The 200M has electric start and 2 piece rear fenders, which no one makes. Good luck finding decent used ones.
200S has no electric start and a one piece rear fender. Maier makes a replacement, but I don't think it has the trunk. Maybe the 200S can be modified to fit the 200M???
Old Aug 14, 2008 | 12:07 AM
xcr800man's Avatar
The 200s was a sport model. It was an upgraded version of the 185s which was a very popular pre-rear suspension sport atv.
The 200m was a stripped down utility model. Very similiar to the original Big Reds of 82 and 83.
Both are decent fun 3 wheelers but the 200s was geared for the sport rider and the 200m was the more dual purpose utility/sport machine.
The 200s is faster and lighter. Depending on what you are looking for.
Old Aug 14, 2008 | 01:46 PM
McDerry's Avatar
The forks are the exact same design, so neither is a better setup. The major differances are frame size as the 200m is a bigger machine, and fork width spacing as the 200m runs 25x12 high floataion instead of the 22x11 like on the 200s.
They dont make 200m plastic. Best bet is a set of trx250 (85-87) that si made by meiers. Its not a dirrect fit, but tis about the right size and shape that it could be made to fit and cover the bike in all the needed areas.
I can get some pictures if you need as I have one of both.
Old Aug 15, 2008 | 11:47 PM
KNOWSALOT's Avatar
The Facility
The 84-85 200M is a hybrid of a 83 200E chassis and an 83 200 engine....... with the only new feature being electric start.
The 84-86 200S is a hybrid of a 83 185S chasiss and an 83 200 engine....... with the only new feature being updated plastics.
Old Aug 18, 2008 | 10:53 AM
bdlight4's Avatar
Thanks for all the replies. I was hoping I could use the tires and gas tank off the S as my son loves the electric start of the M. If the S is faster, I don't want the little gear head to ride that one as he is already crazy on the M. I'll check on the the plastic. Thanks again.
Old Aug 29, 2008 | 09:25 PM
wademc34's Avatar
I have a 1981 honda atc 200.I can't get the carb set to run good so i bought a new carb and it will not run eather. The honda shop guy sead to bolt it on and you will be on your way. He is wrong? or what am i doing wrong? i have spent over 200 dollers on these carb kits and new carbs . What am i doing wrong any one help??????[img]i/expressions/face-icon-small-confused.gif[/img]
bmark0610
Sep 9, 2015 10:56 AM
awer1968
Sep 8, 2015 11:02 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
