ENGINE BRAKE
Old Aug 13, 2008 | 12:32 PM
Br8104's Avatar
Default ENGINE BRAKE
CAN ANYONE TELL ME HOW TO TELL IF A QAUD IS EQUIPPED WITH AN ENGINE BRAKE. THERE ARE NO DECALS SAYING IT HAS OR NOT. IS THE CLUTCH DIFFERENT?
Old Aug 13, 2008 | 12:45 PM
kukerdan's Avatar
when you let off the gas does it slow down or free wheel?
Old Aug 13, 2008 | 12:56 PM
atv gooroo's Avatar
If you look down in the primary clutch(front clutch) and you see a grooved bearing that the belt rides on then yes you have ebs. You can also post your belt number and I can tell you that way because there are ebs belts and non ebs belts.
Old Aug 13, 2008 | 12:58 PM
slashsplat's Avatar
That was the biggest diff between my old Yamaha Kodiak 450 and the 800 X2 Polaris. Let off the gas on the Po, and the thing virtually stops! The Yamaha had enhanced engine braking (both automatic trannys) but was NOT NEAR AS effective.
Old Aug 13, 2008 | 05:47 PM
Br8104's Avatar
BELT # IS FOR EBS, HAVE NOT LOOKED AT PRIMARY BUT WILL DO THAT. WANT TO MAKE SURE IT HAD THE PROPER BELT ON.
BELT BLEW APART, BUT NOT SURE WHY? THANKS
Old Aug 13, 2008 | 06:10 PM
Koerbs's Avatar
JUST LOOK ON THE CENTER OF THE PRIMARY CLUTCH AND YOU WILL SEE GROOVES IN IT.
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
