blaster won t kick start
Old Aug 14, 2008 | 11:33 AM
blasterman831's Avatar
Default blaster won t kick start
i have an 01 blaster rebuilt motor new 30mm kehin carb and a fmf exhaust but my blaster dosen t want to fire when kicked. ican drift start it and it runs good it seems to pop or back fire alittle but it dosen t do it all the time. i really cant figure out what the hells going on. i know it could be jetting but would that prevent the atv from starting. i was thinking my be the reeds are bad
Old Aug 14, 2008 | 06:22 PM
taggart's Avatar
usually if you have bad reeds it will fire up and stop again straight away if you are changing the reeds use carbon fibre race ones . it sounds like you have weak compression but with a rebuilt motor this shouldnt be . if it starts with a pull and drives fine but wont start off the kicker id be looking at compression
Old Aug 14, 2008 | 11:22 PM
Raptor450's Avatar
Yeah I would check the reeds 1st, replace the spark plug if you haven't done so already, and it's probably way too rich, so check the color of the spark plug when you remove it - black is too rich, white/grey is too lean, brown/grey is about right.
Old Aug 15, 2008 | 04:46 AM
hotblooded's Avatar
If you still have your tores or brake saftey hooked up check that, that's what it almost sounds like.
Old Aug 15, 2008 | 10:18 AM
i believe i disconnected the toros set up when i added new carb i just have a straight cable from the carb to the throttle
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
rking85
May 20, 2000 11:01 PM
