800 Sportsman miss w/hot
Old Aug 14, 2008 | 04:10 PM
Polaris quader's Avatar
Default 800 Sportsman miss w/hot
I have a 2005 Sportsman 800 EFI that has started to miss when it gets hot - only. You can hear and feel it dropping a cylinder at idle and continues to get worse the wamer it gets. If you stay at a decent speed (better air flow) this doesn't happen. It does continue to miss under acceleration the warmer it gets. Once it cools off, it runs great for awhile.
I have changed the spark plugs (fun job!) already and checked the plug wires, even moving them around when it's happening, with no luck. The plugs seemed to solve it for a few rides, then it came back. Also ran fuel system cleaner through with fresh gas. It has approx. 2500 miles.
I was thinking it may be the ignition coil causing this, has anyone else had (or heard) of this problem?
Maybe it's time for the new 09?!
Thanks for your help!
Old Aug 14, 2008 | 04:30 PM
HeftyLefty's Avatar
It could be that, or your fuel pump is dying.
Old Aug 15, 2008 | 10:36 AM
Thanks for the suggestion, I'll check the fuel pressure. Are fuel pumps a common problem on a 2005 800 EFI?
Thanks again for the help.
Jmuddin284
Jan 19, 2026 07:16 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Big bousse
Sep 26, 2015 10:42 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sportsman850
Jul 31, 2015 04:25 PM
