port and polish for ds650 baja
Old Aug 14, 2008 | 05:57 PM
Chumly75's Avatar
Default port and polish for ds650 baja
Hey guys one of the shops around here that has a dyno and specializes in high performance says that porting and polishing will open my beast up quite a bit, however another shop that does my routine maintenance says it will not really help out that much. I would appreciate any advice from those who have done it or know about it.
Thanks
Old Aug 14, 2008 | 06:53 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
you have a PM chumly75
Old Aug 15, 2008 | 12:44 PM
Chumly75's Avatar
yeah I do have a pm
Old Aug 15, 2008 | 02:14 PM
DS650ryder's Avatar
lol
Old Aug 15, 2008 | 03:33 PM
Chumly75's Avatar
Wasn't trying to be smart, but I have not recieved a pm from anyone so if you have info I would like to hear from you. I am not wanting to go to the big bore kit but want more power. As it has been stated many times once you start hard to stop....
Old Aug 15, 2008 | 06:18 PM
pipelayer's Avatar
call mr.horsepower at 1-270-334-3331 he has the best port job out and will hook you up with a kick a$$ bike
Old Aug 17, 2008 | 01:03 PM
ERBEDS650's Avatar
Your guy was sort of right, the benefits of spending the money on porting really will not start to show without the combination of higher lift cams, Larger valves, higher compression piston, larger carburetor.
Its sort of a recipe for performance every thing works together to produce the end result.
if your looking at doing these things down the road, I wouldn't spend my money until you have the other items.
Last thing port jobs can run you from 300 to 2000 depending who you go through for whistles and bells, a good head porter will port to your motor build and you type of riding, word of note only trust persons that port that have been doing it at least 10 years and have a good rep, trust me there are deals out there, but also unfortunately on porting you do pay for what you get.
Old Aug 17, 2008 | 08:22 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
ERBE is correct if your staying stock for now the head port is not realy a must.It would not hurt to have your intake ported they are nasty in thier stock form.and there are a few good shops for porting.kenz cycle tech.the bom,custom atv.ron woods,omr (eric) and yes even though i think there customer service is like the worst there ever was Kelly @ kms dose a quality port job. reasonably priced.
Old Aug 18, 2008 | 10:39 AM
Chumly75's Avatar
Thanks for all of your input! I will probably call the bomb eventually as he is only a few hours away and has been very helpful in the past.
Old Aug 18, 2008 | 11:22 AM
ERBEDS650's Avatar
Cant go wrong with Jeff Ross, The Bom! is da BOM!
akguy31
Aug 31, 2019 04:34 AM
franklyme
Oct 21, 2016 07:18 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Brandon400
Sep 5, 2015 08:44 PM
