warrior electrical
Old Aug 15, 2008 | 12:10 PM
ray.sandefur's Avatar
Default warrior electrical
ok well i just charged the battery and put it in the warrior and tried to start it and it just makes a very fast clicking noise.... i found that the noise is coming from a small drum shaped piece of metal on the back right part of the bike ......... does any one know what i should do???
Ray
Old Aug 15, 2008 | 03:17 PM
unhappyraptorer's Avatar
your starter may be in the small drum check your starter connections and make sure they are not coroded or loose
Old Aug 15, 2008 | 03:19 PM
91Warrior357's Avatar
thats your battery cylanoid, usually it clicks when the battery is about dead, is it a new battery? you might have a bad connection somewhere unbolt the wire and take a wirebrush or something to it if its super rusted or anything. otherwise id say your battery cant hold a charge anymore
Old Aug 15, 2008 | 05:29 PM
StngGT350's Avatar
ok you chargedyour battery. that noise if it is a 350 warrior should be coming from the left side right above the rear tire, you will see your synoid. mine did that, i think you might need to buy a new batter considering it does that after a good charge. ended my problem on mine. good luck
Old Aug 15, 2008 | 08:30 PM
jflib74's Avatar
yep solenoid
Old Aug 15, 2008 | 11:27 PM
ok thnx i got it running i stole a battery from a our diff 4wheeler and it cranked it up no problem.... i took it to the sand bar at the redriver and the throttle cable broke (twist grip) so i tried to fix it..... that didnt work so we towed it back in the rain [img]i/expressions/face-icon-small-sad.gif[/img] the wire on the twist throttle broke about a 1cm from the little ball that hold it in place. how much do those run.. and im thinking about buying a normal thumb one for it tho.... what do yall say?
and thanks for the help
Old Aug 15, 2008 | 11:39 PM
Motion Pro prolly makes a thumb throttle kit.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
