warrior electrical
ok well i just charged the battery and put it in the warrior and tried to start it and it just makes a very fast clicking noise.... i found that the noise is coming from a small drum shaped piece of metal on the back right part of the bike ......... does any one know what i should do???
Ray
Ray
thats your battery cylanoid, usually it clicks when the battery is about dead, is it a new battery? you might have a bad connection somewhere unbolt the wire and take a wirebrush or something to it if its super rusted or anything. otherwise id say your battery cant hold a charge anymore
ok you chargedyour battery. that noise if it is a 350 warrior should be coming from the left side right above the rear tire, you will see your synoid. mine did that, i think you might need to buy a new batter considering it does that after a good charge. ended my problem on mine. good luck
ok thnx i got it running i stole a battery from a our diff 4wheeler and it cranked it up no problem.... i took it to the sand bar at the redriver and the throttle cable broke (twist grip) so i tried to fix it..... that didnt work so we towed it back in the rain [img]i/expressions/face-icon-small-sad.gif[/img] the wire on the twist throttle broke about a 1cm from the little ball that hold it in place. how much do those run.. and im thinking about buying a normal thumb one for it tho.... what do yall say?
and thanks for the help
Sw00p
Sep 24, 2015 02:50 PM
