Problem with 04 Polaris sportsman 400
Old Aug 15, 2008 | 03:54 PM
ryeride1's Avatar
Default Problem with 04 Polaris sportsman 400
I own a 04 polaris sportsman 400. When it's hot and I run it up hills it cuts out almost like I'm in reverse without the override switch pressed. I've also noticed it does the same thing when trying to accelerate quickly on level ground. I saw a post below that a fuel system cleaner/dryer may be needed. I'll try that tonight when I get home, but any other help would be appreciated. It seemed to happen right after a put new tires on the machine, maybe a carburator adjustment. Anyone have any ideas.
Thanks
Old Aug 15, 2008 | 04:16 PM
Koerbs's Avatar
Sea foam for a start to get out an water or fix the bad gas if it has some, is your fan comming on at all? Check your spark plug, wire, and coil for damage.
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
