I think she's going to blow!!!
Old Aug 17, 2008 | 02:42 AM
duster's Avatar
Default I think she's going to blow!!!
Well, after all this money spent, I afraid I might have internal issues...
I came back from vacation, went over to where my quads had been being babysit, changed my oil and filter to Mobil 1 20w50 V-twin and a Wix filter.
I heard a tap when I started it back up after the oil change. At first I thought the oil hadn't gotten to the top end yet. But then it persisted right on.
So then I figured it was the valve clearance. So I took it apart for adjustment and it needed nothing there. The tap is still there... I can get it to go away, and it seems to come and go on it's on some.
It's worst on a cold start... so for a bit there I thought it might be how piston slap sounds in the 400. But today I heard it go away while hot and then come back slightly.
Counting me, 3 people suspect the wrist pin is the noise.
Now, beyond that, today I held it at a steady RPM in neutral for just a bit. It started studdering a little and smoking. I can't tell by the color or smell if it's oil smoke though.... maybe because it's synthetic oil burning?...
I went to look for other evidence, but then I couldn't find my plug wrench to get the spark plug out. The best I could do is look in my exhaust tonight. It sure is black, but heavy sutty... not oily.
Old Aug 18, 2008 | 03:37 AM
duster's Avatar
Nobody?
On only have two leads at this point...
Wrist Pin or 'stuck' Decompressor.
Old Aug 18, 2008 | 07:06 AM
270quadsportguy's Avatar
timing chain?
Old Aug 18, 2008 | 06:04 PM
duster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 270quadsportguy
timing chain?</end quote></div>
Could be possible.
Old Aug 20, 2008 | 11:01 PM
those chains are known for strechin easy way to tell is take of top cover from head and check for slop. I just changed a buddy of mines and it sounded like a timebomb. Chain was wasted. Aint too bad changing the chain couple hours and a few gaskets
Old Aug 21, 2008 | 06:56 AM
HondaMechanic's Avatar
Did you try taking the screw out of the center of the tensioner and using a small screwdriver turn the tensioner to see if the noise goes away... Turning counter-clockwise will turn out the tensioner , if it turns out and the noise goes away then you need a tensioner , if it won't turn out anymore (already at it's limit) then you need a new cam chain ..
Old Aug 21, 2008 | 10:06 AM
mudlicker's Avatar
How do you check valve clearance?
Old Aug 21, 2008 | 01:44 PM
duster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: HondaMechanic
Did you try taking the screw out of the center of the tensioner and using a small screwdriver turn the tensioner to see if the noise goes away... Turning counter-clockwise will turn out the tensioner , if it turns out and the noise goes away then you need a tensioner , if it won't turn out anymore (already at it's limit) then you need a new cam chain ..</end quote></div>
No... haven't tried that...
At the "tensioner lifter" on the outside of the engine?
Old Aug 21, 2008 | 10:29 PM
duster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mudlicker
How do you check valve clearance?</end quote></div>
Are you asking as in what are the steps?
If so I can give you detailed instructions.
It's not hard... but would be a pain without step instructions.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
franklyme
Oct 21, 2016 07:18 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Hw00d
Sep 10, 2015 08:53 AM
