Polaris does not have power
Old Aug 17, 2008 | 03:30 PM
aap.1971's Avatar
Default Polaris does not have power
Need Help. My 2005 ranger lost all power except to the fuel pump. Battery is fully charged. I understand there are not any fuses. Does anyone have any ideas on what the problem is?
Old Aug 17, 2008 | 03:41 PM
Koerbs's Avatar
There should be fuses, the atv's have them.
Old Aug 17, 2008 | 09:57 PM
G.A.S.'s Avatar
Kill switch off??
Old Aug 17, 2008 | 11:09 PM
Koerbs's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: G.A.S.
Kill switch off??</end quote></div>
Does a ranger have a kill switch?
Old Aug 18, 2008 | 12:40 AM
<div class="FTQUOTE"><begin quote>Originally posted by: aap.1971
Need Help. My 2005 ranger lost all power except to the fuel pump. Battery is fully charged. I understand there are not any fuses. Does anyone have any ideas on what the problem is?</end quote></div>
Is there power to red/white wire at terminal board next to battery with key on? Does ANY wire at ECM under hood have power? Also there is a brake switch with 2 wires under left front fender that acts as a starter interlock along as a brakelight switch,have had one bad would not start,BUT had power to lights,etc. Jump across the 2 wires and see? Is this a 500 or 700xp? If xp disconnect ECU connector and stick back in,just like rebooting a computer.
Old Aug 20, 2009 | 10:07 AM
KirkH's Avatar
Default same problem here
My ranger was running great yesterday ..my daughter drove it home from a pasture and now it does nothing..its like you aren't putting foot on brake to start..all lights come on..went ahead and recharged battery but it was fine...what could the problem be?..when you turn key nothing happens...
Old Aug 20, 2009 | 02:35 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
IS there a nuetrul saftey switch somwhere on the machine?
Old Aug 20, 2009 | 04:36 PM
eggenz7's Avatar
look at old polaris techs post. describes your problem kirkh
Old Aug 21, 2009 | 08:42 AM
KirkH's Avatar
Default loss of power
old polaris tech is the man..I read his post checked for the brake switch wires and sure enough they had somehow popped off the brake switch...she is back up and running..you guys are great....thanks..for all the replies....sweeeet I say...Kirk
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
RedRancher
Jul 10, 2015 06:36 PM
Jul 7, 2015 11:00 PM
tweeder
Jul 5, 2015 01:57 PM
