no power
Old Aug 19, 2008 | 11:15 AM
200es's Avatar
Default no power
when i turn the key on my 98 scrambler 500 there is no power, no head lights, fan, or electric start. it will only start by pull start, the battery has a full charge, would the voltage regulator do this if it where blown?
Old Aug 19, 2008 | 11:50 PM
Default no power
Check with test light that solenoid is supplying power to starter(next to battery, red wire from battery,the other to starter) can jump across post to see if starter works. Also black pouch in front of solenoid(thermal fuse) see if has power on both sides of red wire,provides power to front,also same type pouch under front panel,check out. If battery good and charged and leads tight,then probably fuse or wiring problem?
Old Aug 26, 2008 | 04:22 PM
ann55's Avatar
Default no power
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
Check with test light that solenoid is supplying power to starter(next to battery, red wire from battery,the other to starter) can jump across post to see if starter works. Also black pouch in front of solenoid(thermal fuse) see if has power on both sides of red wire,provides power to front,also same type pouch under front panel,check out. If battery good and charged and leads tight,then probably fuse or wiring problem?</end quote></div>
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
