REAR A ARM BOLTS
Old Aug 19, 2008 | 10:11 PM
mdj104's Avatar
Default REAR A ARM BOLTS
anyone ever brake the front bolt on the lowre left rear a arm?all my buddys with sportsman have(about 8 of them-all dif. years and sizes)
Old Aug 19, 2008 | 10:22 PM
If you are talking about the left bolt from the a-arm to the hub,then YEP have had a couple break on this same side always the one towards the front! Had one where I had to replace lower a-arm after it bent! DONT know if its torque related or bad run of bolts,or not enough locktite! Usually breaks flush with hub or works out and breaks.
Old Aug 19, 2008 | 10:34 PM
mdj104's Avatar
thats the one.contacted polaris and they said there is no problem.i broke 2 but saved my a arm,others wernt so lucky
Old Aug 21, 2008 | 02:29 AM
Indslpwr04's Avatar
Anyone know off hand what size they are? It sounds like they are something all of us should have in our trail box.
Old Aug 21, 2008 | 05:01 PM
mdj104's Avatar
the bad news is you cant change them without a drill and ez-out if they brake. i got my new ride in sept. so every year in sept. i will change the bolts,it 10$ for all 4,alot better then a-arms,shocks bushing. ect. it seams to always be the front bolt on the lower left arm.
Old Aug 22, 2008 | 12:01 PM
Indslpwr04's Avatar
So the threads snap off in the spindle?
Old Aug 22, 2008 | 04:38 PM
mdj104's Avatar
they bust off flush ,only way out is a drill.if you see the rear left wheel wiggle a 1/2 inch or so when you hit the gas,its broke.as far as i know its only on i.r.s. machines.
Old Aug 22, 2008 | 10:20 PM
JUST REPAIRED ANOTHER ONE TODAY! Total of about 6 for me this year!
Old Aug 22, 2008 | 10:30 PM
Indslpwr04's Avatar
Can they be replaced with a better grade bolt? Or is it an odd size ploaris thing. I;ll go drop the cash right now if possible.
Old Aug 22, 2008 | 10:37 PM
Havent checked,but probably can find stronger grade bolt. I just replace with stock,NO bulletins or team tips on this problem reported to us YET!
