2004 YFZ 450- carb expert needed!
Old Aug 20, 2008 | 02:13 AM
jbull's Avatar
Default 2004 YFZ 450- carb expert needed!
I need an expert to weigh in on my carb issue. First a brief background on what I have. My quad is a 2004, it has an Athena big bore kit with standard compression piston, ported and worked over head, GYTR exhaust and the air box with the mesh style lid with a foam filter and prefilter. I purchased a larger volume accelerator pump cover and installed it. While I had the carb turned, I pulled the plug to check the jetting since I just got the quad recently and it felt like the pipe was extremely hot when I was riding and it backfired quite a bit when I was letting of the throttle. Lo and behold it had a 142 jet in it along with a 42 pilot. To make the long story shorter, I purchased a 170 jet (largest they had at my local shop) and ordered a 45 pilot. Unfortunately, when I pulled the stock jet out, the whole jet extension (needle) came out. When it came out, I noticed there was a small brass fitting that the main jet screws into. The small brass fitting was then screwed into the main jet needle. No big deal, but unfortunately, when I was putting things back together, the brass fitting that holds the main jet twisted off in the needle. I think it had been overtightened previously, as I barely put any pressure on it and it snapped right off.
I went to my dealer, and the brass fitting is shown on the parts diagram for an 04, but it doesn't have a part number. If I order the jet needle, does it come with that fitting? We looked up the carb for a 2005 and it looks like they got rid of the brass fitting and use a little different style (longer?) jet, which seems like a smart idea. What are my options? Can I buy a needle and jet for the 2005 and put it in my 2004 carb? If so, what size jet do you think I should start with? I planned on a least a 170 with a 45 pilot and dropping the clip on the needle to the 4th or 5th position then starting with 2 turns out on the mixture screw. Thanks in advance for any help.
Jeff
neilbedwell
Nov 10, 2018 11:02 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
regiedina@gmail.com
Jun 20, 2015 03:19 PM
