2003 Honda 350 fourtrax smokes
Old Aug 20, 2008 | 08:10 PM
hondaaaa350's Avatar
Default 2003 Honda 350 fourtrax smokes
I have a 2003 honda fourtrax 350es thats smokes (blue) it does it all the time when idling or driving, also a little ticking noise as well. It runs and drives perfect just like it did before it started to smoke any ideas what the cause could be and cost to fix it? It started about a month ago.
Thanks in advance.
Old Aug 20, 2008 | 08:25 PM
HondaMechanic's Avatar
The top end will have to be removed and the piston/cylinder & valves/guides measured ..
Old Aug 20, 2008 | 08:54 PM
so I'm thinking its not a good idea to keep driving it. what kind of money am I looking at to have repaired
Old Mar 4, 2018 | 07:07 PM
ted1's Avatar
Default smoking
do a compression test 90-97 psi is good 65 psi and below is bad ,low compression will give you idling problems and blue smoke .
If the compression is good the valve guides are bad and are letting oil in to the piston causing blue smoke.
you can buy a after market cylinder ,piston , rings, and head kit. for $220 - $275 US from amazon or ebay. head gasket set with valve guides $30 - $75 US .
That does not include cost to install .
Old Mar 5, 2018 | 02:23 AM
Thanks Ted, but this was 10 years ago.
dirt ryder
Sep 27, 2015 09:22 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
