broken drive belt
Old Aug 21, 2008 | 11:38 PM
KyleP's Avatar
Default broken drive belt
I let my friend ride my 2006 sportsman 800 and he hit a ditch he didnt see as he was going across a field at about 20 mph. It broke the a arm and half shaft on the left front it also pushed the fan against the front diff. (I dont think it supposed to be like that). I got it back tonight and the fan is in the same place and when it comes on it is hitting something as it turns. I only made it about 3 miles before my drive belt broke. It has 300 miles and 50 hours on it. Is that normal to break a drive belt or is this from the wreck.
Old Aug 21, 2008 | 11:56 PM
A lot depends on HOW it was driven BEFORE he hit the ditch! Good luck
Old Aug 22, 2008 | 12:11 AM
KyleP's Avatar
I am not sure how it was ridden because I bought it 4 days before he ditched it.
Old Aug 22, 2008 | 10:59 AM
kukerdan's Avatar
that sucks,
I hate lending my bikes out, so I never do!
Only to my most experienced friends who have there own bikes and help me
work on mine.
Old Aug 22, 2008 | 11:49 AM
MECHANIKE's Avatar
10/4 kukerdan, my brother-in-law likes to kick in the awd switch while its spinning around in the winter,blowing hubs+hilliards.he's had quads alot longer than me.he even worked at polaris for alittle while.he just can't figure out the awd part...ever. but never again.
Old Aug 22, 2008 | 12:01 PM
psu111376's Avatar
You should check the clutch alignment. Misaligned clutches will tear up a belt pretty quick. Sounds like it was hit pretty hard, and could have knocked the motor and there for the primary out of place.
Old Aug 22, 2008 | 04:08 PM
sp700cheapskate's Avatar
[img]i/expressions/face-icon-small-mad.gif[/img] I would knock your so-called friends jaw out of alignment! Although it would be a 1 in a million chance, you could have just gotten a bad belt. If it breaks in a certain way, I think it may be covered by polaris. I'd ask old polaris tech first though. If it is covered that is 50-60 bucks you won't have to spend on what already sounds like an expensive F-UP. Good luck.
Old Aug 22, 2008 | 04:15 PM
upnort's Avatar
In 10+ years of owning Po have never broken a belt.
Old Aug 22, 2008 | 04:56 PM
KyleP's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: psu111376
You should check the clutch alignment. Misaligned clutches will tear up a belt pretty quick. Sounds like it was hit pretty hard, and could have knocked the motor and there for the primary out of place.</end quote></div>
They checked everything at the dealership and said it measured strait. I hope nothing is bent that bad but I dont know.
Old Aug 22, 2008 | 05:41 PM
psu111376's Avatar
If the it has been checked then put a belt on it and see what happens. I would check it ofte to see how it is wearing. If it wears excessively or breaks then the clutch are def. misaligned.
