Need help modding scrambler!!
Old Aug 23, 2008 | 01:20 PM
kite_tmr's Avatar
Default Need help modding scrambler!!
I'm looking for some basic mods for my 06 scrambler 500. Looking for:
Clutch kit for low end torque/acceleration (what kind?)
Exhaust that increases torque (what kind?)
Any other suggestions? I want to keep it reliable but would like to increase the low end power. Thanks!!
Old Aug 23, 2008 | 01:30 PM
kukerdan's Avatar
just do a search, this has been covered 1000000 times
Old Aug 23, 2008 | 03:24 PM
SCRAMBLER500XXX's Avatar
AAEN PERFORMANCE
Old Aug 23, 2008 | 05:57 PM
alanalan's Avatar
get a bigger air intake and bigger jets in ur carbuerator
Old Aug 23, 2008 | 05:59 PM
alanalan's Avatar
if u know how to weld u can bye any slip on exhaust ande weld it on it will actually sound better when welded on
Old Aug 23, 2008 | 10:04 PM
scrambler400enoge's Avatar
Shapeshifter Rider
try hpd or ritter cycle racing
Old Aug 24, 2008 | 09:47 AM
ftwflh's Avatar
Now that everyone has pushed their fav aftermarket manufacturer look at my signiture and that is what works on a 500.You can get more with a cam,hi comp piston but the basic mods I have done make it a decent machine.PS clutch kits arent what they are cranked up to be just mix and match clutch parts tro get whet YOU want out of your 500.THis isnt true on the 400s clutching is precise on the piping on those.
Old Aug 24, 2008 | 12:47 PM
kite_tmr's Avatar
Thanks for all the help. If i do a k&n fliter, a pipe and the two springs in the clutch will i see a nice gain? Do i have to do any jetting? Do i have to actually match the springs with the pipe? (somehow? I read that somewhere on this forum)) If so what is a good combo for pipe and clutch springs? (Also, i'm at 6000ft)
Old Aug 24, 2008 | 04:12 PM
ftwflh's Avatar
You will see a nice gain and you dont have to clutch to a pipe on a 500.Jetting will be close at your altitude.
Old Aug 26, 2008 | 12:42 AM
kite_tmr's Avatar
Is the white bros pipe loud? Thats just a slipon right? Any other slipons you would recommend? I will keep stock size piping to avoid losing torque. Should i do anything else while doing the two springs?
I'm really looking to increase torque...
