Need help modding scrambler!!
Old Aug 29, 2008 | 12:02 PM
  #21
kite_tmr's Avatar
Default Need help modding scrambler!!
Thanks again. I'm rethinking my needs. I've been researching clutches and want to make sure i get the right one. I can see what you mean as far as it being easy to get a setup one is not happy with.
If i get the white will i be able to control it well at low speeds, over rocks and stuff? will i lose much of the top end? I just put stock size tires on (bearclaws) but they are heavier so i need to compensate for that.
ftwflh what do you think is the best setup for trailriding? (And what do you think i need.) I ride trails with hardpack, deep snow in winter, lots of rock climbing and some deep mud. (all at 6000-12000ft) I do not need to increase my top end but dont want to lose any either...Thanks again for yourhelp and patience...
Old Aug 31, 2008 | 08:16 PM
  #22
ftwflh's Avatar
White spring will get you a little higher engagement but not much and you will get more top rpms.On the secondary before you get a TEAM try the 2-2 setting.On a TEAM I like the lighter spring it doent react as fast as a heavier one but it gets me more power in the midrange.Not sure what TEAM uses now but I have mine set up for 400 2stroke and it is awsome but not a wheelie machine.I have a 58-44-40 helix with a blk/yellow spring.The 500 set up has a 58-42-40 with a stiffer blk/red spring.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
