00 Sportsman 500 no spark after rebuild
Old Aug 25, 2008 | 01:26 PM
seth25's Avatar
Default 00 Sportsman 500 no spark after rebuild
I bought a 00 Sportsman 500 off a guy that overheated it. He sold it to me as is with engine removed from the bike and engine apart (crank cases not split, but head, cylinder removed).
I got it back together, but I have no spark. Where to start? Take off flywheel and check and clean stator? Is there a CDI test? Ground problem? The engine will turn over fine with the electric start, and I have have compression, but no spark. I am assuming that since the starter will work, my ground is good?
Thanks for the help, great website!!!
Seth
Old Aug 25, 2008 | 07:50 PM
Check resistance specs on stator if have manual,dont have too many problems with coils unless plug wire bad, also pull black wire from cdi and check if has spark. MOST of my problems are stator related,either pulser(pickup) or main charge coil.If either pulser wires shorts to ground(red and red/white could be problem and can buy it separate instead of complete stator. CHECK stator ground wire,usually tied in with other brown wires at coil mount bolt. Keep us posted Good luck
Jmuddin284
Jan 19, 2026 07:16 AM
kelleycully
Sep 15, 2016 02:57 AM
traumajunkie
Jul 5, 2015 03:03 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
