ds 650 choke? and popping
Old Aug 25, 2008 | 06:12 PM
JRock0000's Avatar
Default ds 650 choke? and popping
Is the choke on in or out next ? it runs good with choke *** out it stalls in idle with choke *** in and pops when reved up with *** in? 2000ds 650 biggun exhuast,cdi box,jet kit,and k&n filter
Old Aug 25, 2008 | 06:19 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Choke is off when **** is all the way in. Turn out your air/fuel mixture screw 3-1/2 turns, which is on the front/middle of the carb. I had to do it to mine a little while back.
Old Aug 25, 2008 | 06:28 PM
eddie440's Avatar
does anyone have a picture of the cam timing for a 2004 ltz 400 suzuki? if so i could really use one email to eddiedragracing@yahoo.com
Old Aug 25, 2008 | 06:37 PM
JRock0000's Avatar
thanks silverbomb i'll give that a try!!!
Old Aug 25, 2008 | 06:50 PM
JRock0000's Avatar
also where is the idle screw?
Old Aug 25, 2008 | 07:29 PM
SilverBomb's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eddie440
does anyone have a picture of the cam timing for a 2004 ltz 400 suzuki? if so i could really use one email to eddiedragracing@yahoo.com</end quote></div>
Eddie, go to the Suzuki section and you might get better results.
The idle screw is on the left side as you're looking down from sitting on the seat. It looks like a **** with a screw in the middle. Right turns up the idle, left turns it down if I remember right.
Old Aug 26, 2008 | 06:11 PM
yellowdemon23's Avatar
Me and some of my buddys were riding the other day, just got the ds650, and that's all it would do was pop. Wasn't responsive at all, would run better with half choke, so we figured that it must be getting too much air. So I took my sock off, put it over one of the airbox tubes, and it ran like a champ. It had a new K&N airfilter on it. So I figured it was just the filter so I ordered a factory air filter, put it on did the same thing, just not as bad, but I still have to run it with one of the air tubes blocked off. So now I'm thinking someone rejetted the carb or something. Anyone had this problem?? Maybe this will help you.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
