DS650 Carb Rebuild Kit
Old Aug 26, 2008 | 05:52 PM
yellowdemon23's Avatar
Default DS650 Carb Rebuild Kit
Just like the topic says, does anyone make a rebuild kit for the ds650?
Old Aug 26, 2008 | 11:46 PM
YAMASUXHONDUST's Avatar
NO I HAD THE SAME PROBLEM ORDER EACH ITEM I NEEDED AND REBUILT IT MY SELF
Old Aug 27, 2008 | 01:35 AM
Mine Runs Great, but is a pain to start, It drips gas out of the bottom of the bowl, I have stock air filter, stock carb, but I have to plug off one of the tubes going to the air filter or it runs like crap. So I believe I have a jet that is clogged up.
Old Aug 27, 2008 | 11:02 AM
WLD_OTZ's Avatar
You can buy a new needle and seat valve, they are about 55.00, and for the clogged jets, what I did was pull the carb, remove all the rubber bits, o'rings, needle valve, everything that isn't brass or aluminum, and get a can of the soak-in carb cleaner. You can get that at any auto parts store, it is about 20.00. Soak the carb, blow out all the jets, and dont forget about the little air jets at the inlet of the carb as well as the top of the carb under the diaphragm.
I pulled all my jets, but it *may* work without pulling them. They are easy to put back in, just take a digital pic before you take them out so everything goes back into the right hole.
Cheers, John
Old Aug 27, 2008 | 11:08 AM
Thanks I appreciate it
Old Aug 27, 2008 | 06:35 PM
WHEN U DO THAT CARB REBUILD DO THE OMR HOP UPS FOR THAT CARB IT REALLY HELPED ME ALOT. I GOT MY DS ABOUT A MONTH OR TWO AGO IT WAS DRIPPING ALSO ALL THE ORINGS WERE DRYED OUT ? YOURS ON THE LEAKING MIGHT B FLOAT NOT ADJUSTED RIGHT IF ITS BEEN SETTING WITH GAS THE ORINGS MIGHT B YUR PROBLEM. THAT OMR IS IN THESE FORMS SOME WERE
Old Aug 27, 2008 | 06:37 PM
Okay thanks a lot
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
