NEED SOME HELP ON A BLASTER UPGRADE
Old Jan 29, 2001 | 01:00 AM
atvtrader's Avatar
I've got got a chance to buy a blaster with a blown motor and i was wondering if anyone knew if i could put a dirt bike motor on it any help or advice would be greatly apperciated
Old Jan 29, 2001 | 01:32 AM
NewDSLover's Avatar
Well, that's a deep question! Here's my two cents.
I would only try to adapt a bike motor if (1) -it's free, all ready have it, or cost little and your trying to save money.
(2) - It's not a big motor, the problem is the frame, susp.., and everything on a blaster isn't made for this. And if you do put a different motor in it, it's highly likely your be rigging it to run before, during and after each ride to keep it running.
(3) - if the blow blaster motor is only the top end. Then your only talking about $150 bucks or so for a Wisco Piston, Gasket Set, Bore Job along w/ the standard Pin, Clips and Bearing. And while jug is off, do a porting job to add alittle more hp's. Air cooled 2-strokes are an easy engine to rebuild. Good Luck.
Old Jan 30, 2001 | 09:09 AM
jeepin's Avatar
I did the same thing.I bought a 1990 blaster for 500 bucks needed a top end though.It wouldn't have been that great of deal except the plastic was in very good shape.had a BRAND new carb on it.never been ran with the carb,new brake pads,axle bearings and carrier and some other stuff.I had it bored a small as possible for the scrathes..025 over.Got a pro-x piston rings and circlip and low-mid porting and and a new uni filter for $170.00.It runs great but now it needs swingarm bearings.
moded out 86 trx250r
97 300ex
90 blaster
Ahtatu
Sep 28, 2015 12:14 PM
jankerstien
Sep 21, 2015 03:09 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Brandon400
Sep 5, 2015 08:44 PM
