Maybe a Dumb one
Old Aug 28, 2008 | 03:16 PM
immerume2's Avatar
Default Maybe a Dumb one
I know when you push the button your quad can reverse more smoothly. Does it make much of a difference? I have never had problems reversing in or out of something without the override. Just wandering if I was missing some mechanical benefit or otherwise.
Old Aug 28, 2008 | 05:23 PM
Honda777's Avatar
I think it's only there to slow one down so you don't crash into stuff while backing up.
Old Aug 28, 2008 | 05:24 PM
mechanicock's Avatar
it overides the rev limiter. While in reverse the limiter wont let you go but so fast or reach a certain RPM unless you "override" it. Hope this helps.
Old Aug 28, 2008 | 05:42 PM
Mile High's Avatar
If you have never had to use the over ride when backing up you must not get into very ruff stuff. I have to use mine all the time up here in the mountains. I love that little button.
Old Aug 28, 2008 | 06:32 PM
immerume2's Avatar
They actually don't have one standard on the wolvy. People are installing them. I can go pretty fast without the limiter. I guess the limiter would just slow it down so that I don't over rev in reverse? So if you don't have one you should just take it easy using the reverse?
Old Aug 28, 2008 | 06:50 PM
Mile High's Avatar
You won't over rev in reverse. More what it is used for is like this: You're on a narrow trail and the only place to back up is up an incline or over several large rocks. When you hit the rocks or have to pull up the incline the engine will strain harder than when on flat ground which forces the rpm's higher. Once the rpm's hit the limiter the engine starts cutting out so you won't have the power to get over that obstacle. That's when the over ride button comes into play. Over ride the limiter so you have the power to back up. It's totally worth it. I have been on trails so steep that the ATV would not back up without the over ride. It has more to do with having the power you need instead of speed.
Old Aug 28, 2008 | 07:00 PM
immerume2's Avatar
I guess i just kick it into 4 wheel or tell myself i have to go foward. Thanks for the info.
Old Aug 28, 2008 | 07:21 PM
Mile High's Avatar
On top of a mountain there may not be a forward option. Some day being able to go backwards in 4X4 without the rev limiter may save your hide...just speaking from experience.[img]i/expressions/face-icon-small-wink.gif[/img]
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
brokemybanshee
May 1, 2001 12:04 AM
RaptorRules
Nov 8, 2000 04:58 PM
SWAC
Feb 17, 2000 03:04 PM
Rocky
Jan 6, 2000 05:04 PM
