2000 wolverine clutch
Old Sep 1, 2008 | 10:18 PM
dylanr's Avatar
Default 2000 wolverine clutch
The clutch on my 00 wolverine 350 is starting to slip pretty bad due to many hard winters of plowing, and turning big tires. Has anyone ever changed one of these semi auto clutches? I am worried about adjusting it, any help or pictures would be great, thanks
Old Sep 1, 2008 | 10:22 PM
cadillacdude1975's Avatar
http://www.youtube.com/watch?v=br63PLcq3sU
have you ever adjusted the clutch before? if not, you can adjust that bad boy and save yourself about 75 bucks. on the left side of the case there is a locknut and a threaded screw head. loosen the locknut, turn the screw to decrease about an 8th of a turn, lock it down, ride it. it might need a little more if you have never adjusted it. just adjust a little, lock it down and ride it. if the clutch has never been adjusted, you should be fine with doing that. i recently had to do that to my 99 big bear. it had never been touched and i rode it one weekend and the next day the damn thing would fall out of a tree. i did some reading, adjusted the clutch, and i have been giving it hell ever since on the factory installed clutch.
Old Sep 1, 2008 | 11:52 PM
dylanr's Avatar
i turned in that screw, but all it did was make the shifter all floppy, and made it verry hard to shift. the video was on manual clutches, i have done them before, but i have a feeling the auto clutch has a bunch of springs and crap, i dont like springs...
thanks tho
Njrider1230
Jul 29, 2023 05:16 AM
cdstang
Aug 31, 2015 07:52 AM
Dan Newberry
Aug 30, 2015 09:42 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
