Wiring problem
Old Sep 5, 2008 | 02:54 PM
Bert 250's Avatar
Default Wiring problem
I have a honda 250es and you can on start it when you connect the battery directly to the starter motor. And whenn you connect the battery to the statter relay and press start it does not work, does anybody know what the problem is.
Old Sep 7, 2008 | 03:04 PM
splescort's Avatar
so the IGN key is on and the head light switch is on low beam???
for some reason that is the only way that my electric starter will work and my wiring is stock untouched 1983 200e
Old Mar 21, 2010 | 01:09 PM
drjoe171's Avatar
Default spark oddities
it's looking for an alternate ground so it will run. Mine will only spark withOUT the battery connected even tho it spins good and fast with the starter. ...NO spark. Disco the battery and it sparks Gotta be looking for a way to compensate for a weak ground but haven't found it yet Some folks give up and put in a new wire harness cheaper and faster than m,essing with them for months and then who really cares what was wrong. it runs
Old Mar 24, 2010 | 08:13 PM
Kawboy03's Avatar
Default Relay
I would check the 'starter relay'. That is what the relay is for...it allows you to use the starter button and send power to the starter.
Ragtop
Jun 27, 2015 03:04 AM
FWhitt
Jun 13, 2015 02:22 PM
wildbill59
Jun 9, 2015 02:28 AM
elpayaso
Jun 3, 2015 10:39 AM
elpayaso
May 30, 2015 05:43 PM
