95 scrambler will not run
Old Sep 11, 2008 | 11:00 PM
EPeterson's Avatar
Default 95 scrambler will not run
Okay, now that I have replaced the head gasket, put in a new main jet b/c the other one fell out , cleaned that carb. the darn thing will not start with out starting fluid. i have adjusted the the carb to the settings in my shop manual. I looked at the throttle assembly and noticed that there was a wire that was broken, it is broken right at the switch. I unplugged it will not idle at all,you can rev it up and it boggs down. please any one with knowledge of the 400 2 stoke give me some help.
Old Sep 11, 2008 | 11:18 PM
scrambler400enoge's Avatar
Shapeshifter Rider
The silencer could be plugged up with carbon deposits thats the issue I experienced
Old Sep 11, 2008 | 11:43 PM
If switch is the one that plugs into throttle assy, its the ETC switch, repair wire, adjust throttle cable slack to about 1/8" play in lever,then tighten cable locknut,then can adjust carb idle
Old Sep 12, 2008 | 12:26 AM
EPeterson's Avatar
will that work even with the broken wire on the etc?
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
