blowing headlights
Old Sep 12, 2008 | 11:43 AM
DSDEMON's Avatar
Default blowing headlights
it is a 2001 ds racer and i put in a new regulator and can not find any place it should be shorting out.
thanks.
Old Sep 14, 2008 | 06:22 PM
DSDEMON's Avatar
Nobody has had this problem or knows what it might be.
Old Sep 14, 2008 | 10:02 PM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
check the light switch on the bars. it may have a short in there.
Old Sep 14, 2008 | 10:40 PM
yellowdemon23's Avatar
There has to be a short somewhere, does your tail light work when the head light is out?
Old Sep 14, 2008 | 11:20 PM
Williebee's Avatar
How often do they blow ? As soon as you put in a new bulb , or does it blow them shortly after you replace the bulb ?
The reason i ask is that i had a 1993 Suzuki LT4WD 300 KQ that blew the bulbs in a very short peroind of time , however this quad had the 4 headlamps and would blow one and the other soon after replacement of the first one to blow ; it turned out to be the lack of using Di Electric grease on the bulb contacts and bulb sockets !........
Old Sep 15, 2008 | 11:18 PM
DSDEMON's Avatar
i checked out headlight switch(looked fine)
taillight works
it blows them shortly after but usually the first long ride.
Old Sep 18, 2008 | 10:52 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Do the bulbs burn out or shattter? What type of bulbs and whatage are you using ?
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
PrairieDog126
Sep 16, 2015 01:33 PM
