Other ROTAX engines
Old Jan 29, 2001 | 11:53 PM
Fast650's Avatar
What other motorcycles use the Rotax engine? Do you think it could be used as a direct replacement on the DS?
Thanks for your help.
Old Jan 30, 2001 | 03:06 AM
WRECKED's Avatar
The DS650 engine is the same as the BMW F650 Funduro motor.
Old Jan 30, 2001 | 01:03 PM
KillaATV's Avatar
Does the BMW F650 Funduro have the same rev limiter as the DS or does it have a higher rev limit and are they interchangable? If there is a higher rev limit how much higher is it?
Old Jan 30, 2001 | 04:13 PM
BrassPad's Avatar
ATK also used the Rotax engines. Several different ones. They have one 4-stroke model, and its a 650. A couple of years ago, they came out with a 650 4 stroke quad. It cost $12,000. The reason was ATK doesn't build anything but the basic frame. Then they purchase the best aftermarket parts and use them to build the rest. The motorcycles aren't the best in the world when them arrive though. The trannys are very notchy, and the engines can't keep up with the Jap bikes as far as power output. But with a little work, they are really good performers and can hang with them all. Their designs are a little dated too.
Old Jan 30, 2001 | 04:24 PM
hou650's Avatar
KillaqATV.
The CDI used on the BMW F650, Is the same one Ron Woods sells. Ron Woods is cheaper.
Old Jan 30, 2001 | 08:44 PM
ScoobyDFW's Avatar
The BMW F650 CDI box has no rev limit and runs $350 new.
You can run an aftermarket CDI on the DS.
The F650 has a 5 valve head, dual carbs, and must have a differnt primary reduction ratio than the DS650 motor.
Old Jan 30, 2001 | 09:55 PM
KillaATV's Avatar
So will the F650 rev box work or not?
Old Jan 30, 2001 | 11:06 PM
ScoobyDFW's Avatar
Yes as far as I know the F650 rev box will work. I've heard of one guy that was running one. Alba said they have them to sell.
Old Jan 30, 2001 | 11:13 PM
KillaATV's Avatar
Thanks, gonna start to call around at some of the bike junk yards near my area. Try to save some bucks. I know this F650 was'nt a big seller but maybe I can get lucky.
Old Jan 30, 2001 | 11:37 PM
ScoobyDFW's Avatar
Don't forget that the woods rev box has 4 degrees of ignition advance at the lowend and eliminates the retard at 6500 RPM, allowing the motor to rev more freely. The PAMI box should be similar to the woods box. The F650 CDI may still have the retard at upper RPMs.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
