660 raptor idles fine but wont run just spits HELP!!!
Old Sep 14, 2008 | 03:40 PM
cms10balla's Avatar
Default 660 raptor idles fine but wont run just spits HELP!!!
i just bought a 01 660 raptor and took it ridin 2ce both times washing it after... then i went to start it up today and it started but when given gas it would just pop and spit...wat could be wrong.. it goes in gear and idles fine and stays running just when given gas it pops and sputters... plz give me sum info i could do or need to be checked over to maybe fix it cause i dont wanna take it into the shop.. thanks.. my email is hostetler_truck@windstream.net thanks
Old Sep 15, 2008 | 02:37 PM
95wolv's Avatar
check the parking brake, it has a switch that will make your quad cut out above idle, this is to prevent taking off with the parking brake on, but often the switch goes bad, causing that problem. find the 2 wire plug by the brake lever, unplug it and see if that helps. keep us informed on how it goes.
Old Sep 15, 2008 | 03:55 PM
HeftyLefty's Avatar
You probably have moisture from washing it in your electrical connections. Remove the seat and plastics necessary to expose the wiring harness. Disconnect battery, unplug all harness connections, spray them with WD40 (it displaces moisture) and allow to air dry. Don't forget the spark plug boot.
Then put a thin bead of #2 Permatex Make a Gasket-available at auto parts stores- on the outside of each male connector in the harness, and push the connectors back together. Put a ring around the spark plug ceramic to seal the plug boot. Check boot for cracks.
While the plastic is off, check carb vent tube for kinks /cracks, and check airbox for water. You may have gotten your filter wet. Also check the gas tank vent tube, there may be water in it.
Old Sep 15, 2008 | 05:04 PM
07wolverine05rincon's Avatar
My Wolverine is doing it...believe it's the speed control sensor, but I have yet to locate mine. LOL
Old Sep 16, 2008 | 08:05 AM
Slaxxor's Avatar
You might also check the reverse sensor.
I had the exact same systems until I disabled my reverse limiter.
SDR-II
Sep 29, 2015 01:06 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
